SCT 2step feature
Old Aug 21, 2008 | 09:42 AM
rford426's Avatar
rford426
Default SCT 2step feature
Hey i have the strategy flash just like the xcal 2 how do i turn on the 2step feature??? I have the neutral rev limiter set at 4100 rpm and it is activated even when im not in neutral there for it kicks in when im normal drivin or there for gettin on it?? any suggestions?
Old Aug 21, 2008 | 02:56 PM
VistaStangGT's Avatar
VistaStangGT
I would suggest not using that functionality as a 2 step. It cuts fuel not spark which isn't good for the engine. If you want want a good 2 step, MSD has one that has gotten great reviews.
I think it's called launchmaster or something like that.
Old Aug 21, 2008 | 02:57 PM
DarkFireGT's Avatar
DarkFireGT
It has to be activated by whoever writes your tune.
I personally wouldn't do it. It's dangerous. To limit the RPMs, it cuts fuel, causing the car to lean out. You also have to deactivate the switch on your clutch pedal that turns cruise off when you depress the clutch. If you want a 2 step, pick up the MSD Launch Master.
firehorse02
Nov 16, 2015 11:28 AM
lincolnshibuya
Oct 6, 2015 08:45 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
03blackwidow
Sep 20, 2015 02:36 PM
