Zex install
Old Aug 23, 2008 | 08:58 PM
white07's Avatar
white07
Originally Posted by JimC
The Speed of Sound switchplate is easy. Take off the driver side front wheel and pull the wheel liner so you can run the wiring to the inside through the rubber plug you will see. On the center console, open the lid and take out the two screws, pull the parking brake up to the full on, if you have an automatic pull up the trim around the shifter (it is held in by friction so lift one edge and you should be able to pull it up easily) and then wiggle the console cover off. I tapped the wires right there for the power point plug in the console for power to the switches and the ground. Drill a hole in the second drink holder for the wiring (pull the false bottom out first) and feed your wiring through. The trim on either side of the radio just pulls straight back once you remove the console cover.
Yeah I need to install my SOS switch panel too.
Got my window switch yesterday and my A/f Gauge and nitrous pressure gauge will and a-pillar pod should be here soon so Ill finish installing everything.
I all ready have the bottle in, lines ran, and the control module or w/e bolted up under the hood.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
