Zex install
Old Aug 22, 2008 | 10:10 PM
tombohum's Avatar
tombohum
Default Zex install
Hey guys I just recieved my Zex wet kit today (from smythge) and I plan on installing it Sunday. If any of you know of any tutorials they would help out alot. I also have the window switch and Speed of sound switch panel so installs of those would be great too.
Old Aug 22, 2008 | 10:29 PM
smythge's Avatar
smythge
Glad you got the kit ok, follow the manual and you shouldn't have any problems. E-mail me and will tell you how I had it wired and and where I had the purge located.
Old Aug 23, 2008 | 01:42 AM
mac10chap's Avatar
mac10chap
i just got done with my install of my zex kit. added purge kit, bottle heater, remote bottle opener and window switch. if you get stuck or need help in any area, let me know and i can take pics and point you in the right direction. good luck
Old Aug 23, 2008 | 07:21 AM
MustangBatman1's Avatar
MustangBatman1
It's very straight forward if you follow the directions, pretty easy install.
Old Aug 23, 2008 | 10:25 AM
157dB's Avatar
157dB
Cut & Paste Expert
Go to your local magazine rack and look in the
September issue of MuscleMustangs&FastFords
for a 'detailed with pics' write-up on the whole ZeX install.
There is a pic of the purple ZeX NO2 bottle on the cover.
Old Aug 23, 2008 | 11:13 AM
06elnr's Avatar
06elnr
it is easy...you should have no problems.
Old Aug 23, 2008 | 11:19 AM
smythge's Avatar
smythge
This writeup was helpful to me
http://www.mustang50magazine.com/tec...tem/index.html
Old Aug 23, 2008 | 12:22 PM
white07's Avatar
white07
was the purge kit easy? There are bunch of little parts and it looks complicated
Old Aug 23, 2008 | 05:22 PM
mac10chap's Avatar
mac10chap
it was really easy. all you do is tap into the nitrous out line and mount the purge behind the grille. the wiring is all very self explanitory.
you will need to pull off the radiator cover as well as the grille unless you plan on mounting it close to the windshield.
Old Aug 23, 2008 | 07:47 PM
JimC's Avatar
Super Moderator
The Speed of Sound switchplate is easy. Take off the driver side front wheel and pull the wheel liner so you can run the wiring to the inside through the rubber plug you will see. On the center console, open the lid and take out the two screws, pull the parking brake up to the full on, if you have an automatic pull up the trim around the shifter (it is held in by friction so lift one edge and you should be able to pull it up easily) and then wiggle the console cover off. I tapped the wires right there for the power point plug in the console for power to the switches and the ground. Drill a hole in the second drink holder for the wiring (pull the false bottom out first) and feed your wiring through. The trim on either side of the radio just pulls straight back once you remove the console cover.
