How to install headlights?
Old Aug 26, 2008 | 05:20 PM
bolivianpimp's Avatar
bolivianpimp
Default How to install headlights?
Hey everyone i am purchasing new projector headlights, front bumper lights, and rear side marker lights. Does anyone know where to get instructions on this? I tryed doing a search with no luck. thanks
Old Aug 26, 2008 | 06:17 PM
0NF1R's Avatar
0NF1R
well its easier said than done...to remove your stock headlights, you will need to remove your entire front bumper...you will need a grinder the grind down the rivets holding the front bumper on as well....once it is remove, you can easily accessyour headlight bolts and remove them...with your bumper cover off, you will see on the inside of the bumper, the back of your front corner lights...they are held in place by plastic clips...just work the light and it will come right off of the clips...as for the rear side marker lights, you just need a flat head screw driver to gently pry up on the side of the light cover that is closest to the rear of the vehicle then it will come right out...
Old Aug 26, 2008 | 06:20 PM
pascal's Avatar
pascal
S197 Section Modder-ator
No! There isn't any grinding involved in this!!!!
Mike, you're scaring me.
Old Aug 26, 2008 | 06:46 PM
rmssch89's Avatar
rmssch89
If I'm correct the only time grinding is needed is when you are transferring the entire side marker assembly to a new bumper. Even then, you could probably just drill out the rivets carefully. I know I had to do it when I installed my Roush fascia.
Old Aug 26, 2008 | 06:53 PM
pascal's Avatar
pascal
The OP isn't changing the bumper, just the lights.
Different story here.
Old Aug 27, 2008 | 05:08 PM
bolivianpimp
So does anyone know how to? lol
Old Sep 1, 2008 | 10:09 AM
0NF1R's Avatar
0NF1R
he is keeping the bumper but changing out al lthe lights....most will tell you some grinding is required because there are a couple of rivets that you will need to break...i cant remember whether it was for the bumper or the front marker lights, but some grinding was required when i installed my roush bumper but used my side marker lights from the original bumper on the new bumper....note, the grinding is only needed to break the appx 2 rivets...
Old Sep 1, 2008 | 10:40 AM
mlcrycc's Avatar
mlcrycc
http://www.2005stang.com/gallery/alb...t%20bumper.pdf
Follow the above for the bumper cover only....
http://www.2005stang.com/gallery/alb...1/headlamp.pdf
Then this for the headlights....
Finally, you can use this for the front and rear side markers....
https://mustangforums.com/forum/show...smoked+stealth
Hope this helps,
Mike
Old Sep 1, 2008 | 10:41 AM
pascal's Avatar
pascal
It was for the bumper swap...
The bumper brackets are secure with rivets.
The turn signals snap into 2 clips that are on those brackets (After you slide it in that slot at the other end)
NO DRILLING REQUIRED FOR ANY KIND OF LIGHTS THROUGHOUT THE ENTIRE CAR.
Mike, don't take it wrong please, I'm just saying...
Old Sep 1, 2008 | 02:30 PM
0NF1R's Avatar
0NF1R
ya man np im not taking it the wrong way, i was just saying that some grinding is required since you have to remove the bumper cover to change out your headlights...i didnt say anything about drilling lol ;-)
