How to install headlights?
Old Sep 2, 2008 | 11:20 AM
bolivianpimp's Avatar
bolivianpimp
What is the size of all those bulbs? So, i will have to grind 2 rivets to take bumper off? what size? What other tools do i need?
Old Sep 2, 2008 | 11:48 AM
tn_gt's Avatar
tn_gt
lol no rivets need to be broken for anything, headlights foglight or side markers.....
Old Sep 2, 2008 | 06:15 PM
0NF1R's Avatar
0NF1R
maybe not on the 08's but on my 05, i was at the shop when they needed to do some grinding with a cutoff saw/grinder when i had my bumper and lights all changed out...i saw the grind marks with my own eyes and i dont think theyd grind just some random area of plastic to see if theirs worked properly ;-)
Old Sep 2, 2008 | 06:26 PM
howarmat's Avatar
howarmat
s197 Junkie
You can follow this to get your bumper off
http://www.cherod.com/mustang/HowTo/...sciaInstal.pdf
and if you look here
this is the only time grinding is needed. You are swapping the complete turn signal out. Otherswise its all nuts and bolts.
Old Sep 2, 2008 | 07:33 PM
Vader GT's Avatar
Vader GT
I have not changed out the turn signals, but my friend had an 06 & I changed his front headlights out. No need to remove the entire bumper, just loosen one side at a time. It takes a little patience & some moving around, but I did not have to remove the entire front bumper. Good luck!
Old Sep 4, 2008 | 10:18 AM
0NF1R's Avatar
0NF1R
yes, it is possible to change out the headlights just by loosening the bumper...the only reason you have to loosen or remove the bumper is to access the lower bolts on the headlights....post up a pic once youre all done!
Old Sep 4, 2008 | 11:23 AM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Go to my conversion thread and follow the instuctions for removal of front bumper. Its real easy and you wont need to grind anything off. Just pop the off and re-attach them with a zip tie. Mine has been on for 1.5 years and still holding strong.
Old Sep 4, 2008 | 11:30 AM
157dB's Avatar
157dB
Cut & Paste Expert
TRY THIS
AND THIS
Old Sep 4, 2008 | 01:34 PM
tn_gt's Avatar
tn_gt
well i didnt have any rivets on mine, and i did have to take the bumper all the way off as there were two plastic peices sticking out of my bump that slid into part of the headlight and i didnt want to cut those off or anything...all in all i could do a complete swap in about 30 minutes if i had to again
mtgldr
Feb 3, 2024 09:00 PM
StalkerGT
Nov 28, 2015 03:09 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
