P0430 code
Old Sep 1, 2008 | 04:18 PM
surf808's Avatar
surf808
Default P0430 code
I've gotten this code twice now and I keep clearing it. I know it has to do with the cat. I recently installed BBK LT with the catted x pipe. Do you think something is wrong with the catted x pipe as its only one side? However, the car runs great and I don't smell any extra exhaust fumes.
Any help or ideas would be greatly appreciated.
Old Sep 1, 2008 | 04:26 PM
jwog666's Avatar
jwog666
p0430 means the cat on bank 2 isnt working, bbk may senda replacement cat for free. check your warranty
Old Sep 1, 2008 | 08:54 PM
surf808's Avatar
surf808
I sent BBK and Brenspeed emails. I'll just wait and see what they say.
Old Sep 1, 2008 | 09:31 PM
157dB's Avatar
157dB
Cut & Paste Expert
Possable causes:
Damaged Heated HO2S sensor
Out of range ECT sensor
High fuel pressure
Damaged Exhaust Manifold
Damaged Catalytic Converter
Oil Contamination
Cylinder Misfiring
Downstream HO2S wires improperly connected
Damaged Exhaust System pipe
Damaged Muffler/Tailpipe assembly
Retarded Spark Timing
Leaking Fuel Injector
Old Sep 2, 2008 | 02:25 PM
surf808's Avatar
surf808
Thanks for the info. Brenspeed said I should try a spark plug non fouler. It will move the o2 sensor farther out of the exhaust gases and perhaps trick the computer.
Old Sep 2, 2008 | 04:09 PM
onederful100's Avatar
onederful100
are your rear O2 sensors off? i've heard of a few people w/ catted mid pipes get a CEL like they dont have cats.
Old Sep 2, 2008 | 04:14 PM
157dB's Avatar
157dB
Cut & Paste Expert
How about some MIL eliminators for the O2 sensors?
Old Sep 2, 2008 | 04:56 PM
surf808's Avatar
surf808
No I don't think they are off. Can I turn them off my self or does Brenspeed need to do it?
Old Sep 2, 2008 | 05:13 PM
onederful100
you should be able to turn it off yourself, if brenspeed left the adjustable options on. i have custom tunes which one i can change things, the other 2 i can't. if you cant, brenspeed should send you an email tune w/ them off.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
