hurst shifter help please im goin nuts
i have the new hurst shifter and love it but i got a rattle and it sounds like it s coming from the shifter. when i rev it in neutrel you hear the rattle then when i do it and pull the handle it goes away so its the shifter and it is not the handle its in the shifter itself. so what should i do i got it 3 months ago from mustangs unlimited. now if i get another one will i have the same problom or should i get somethign else???????????
First, double check everything for tightness...
Second, the washers that come with that shifter aren't that great IMO.
Replace them with copper ones and crank that sucker good.
On mine, I did use longer bolts and put a nut on the other end with the above mentioned washers. It was 2 years ago and this thing is as tight as a virgin nun and vibrations free.
