Where to buy IPOD plug for 07+ mustang?
Well, you have 2 options. You can use a 3.5mm to 3.5mm and use the headphone jack. You get decent sound out of it. The benefit to that is you can charge the iPod at the same time. Otherwise, you can get the dock to 3.5mm cable, and you get much better sound. With that one, you can't charge at the same time.
3.5mm to 3.5mm
http://www.amazon.com/PCMICROSTORE-R...0792845&sr=8-6
dock to 3.5mm
http://www.amazon.com/Logic3-iPod-3-...0792845&sr=8-7
3.5mm to 3.5mm
dock to 3.5mm
3.5mm to 3.5mm
dock to 3.5mm
3.5mm to 3.5mm
dock to 3.5mm
uhmm, while that is true, what I mean is that if you're using a dock to 3.5mm adapter, you can't charge your iPod at the same time because the dock connector is being used only to send sound out. The 3.5mm aux jack will not charge the iPod.
get the belkin car kit. it plugs into the 12v power outlet. the headphone jack then gets plugged into base of the 12v socket. you have one wire coming of the center console, and it changes you iPod everytime its plugged in.
http://catalog.belkin.com/IWCatProdu...duct_Id=149006
