Sponsored by:
Sponsored by:
Steeda LCA
Old 09-08-2008, 11:52 AM
Riptide
Riptide's Avatar
Default Steeda LCA
How are these? Any reason not to use these vs. some of the other options on the market?
http://www.steeda.com/products/steed...ntrol_arms.php
Riptide is offline
Old 09-08-2008, 12:24 PM
degeze
degeze's Avatar
I have not personally used them but I seen them and they are very well made. If you plan of lowering your car someday you might want to consider adjustable LCAs (or adjustable UCA) to correct pinion angle. The reason I suggest adjustable LCA is that they are easier to access/adjust than a adjustable UCA if needed. If you do not have plans of lowering then these would work just fine.
degeze is offline
Old 09-08-2008, 12:28 PM
Riptide
Riptide's Avatar
Yep no plans on lowering. Wish I could but MT has bad roads and ugly winters. Not a good idea here.
Thanks for the feedback.
Riptide is offline
Old 09-08-2008, 12:30 PM
rad_rob
rad_rob's Avatar
You should check out the Currie aluminum lower arms too. I have them on mine and LOVE them.
rad_rob is offline
Old 09-08-2008, 12:44 PM
degeze
degeze's Avatar
I know you said you do not have plans of lowering the car but the price of the Steeda non-adjustable LCAs are $50 cheaper than the BMR adjustable "Street" LCAs. If you saved up $50 more you could have adjustable ones, just a thought. If something changes in the future (repaved the bad roads) and you wanted to lower your car you would already have the LCAs for it .
degeze is offline
baddog671
07-26-2016 01:20 PM
Florida Regional Chapter
09-30-2015 08:04 PM
UrS4
09-30-2015 10:13 AM
09-24-2015 09:18 PM
Quick Reply: Steeda LCA
