Losing Tranction Control
Old Sep 8, 2008 | 02:03 PM
AzPete's Avatar
AzPete
One thing I found is traction control only kicks in if one wheel is spinning faster than the other. I have played around on freshly rained on roads and found it is possible to spin both rear wheels with the traction control ON. It will not last forever, but I was surprised at how long it actually spun and it was long enough to get into trouble.
I have driven rear wheel drives all of my 50+ years. It is no problem handling as long as you respect it.
Old Sep 8, 2008 | 02:31 PM
jahudso2's Avatar
jahudso2
I have trouble getting my rear end to come around even when I want to. You guys must be driving like maniacs to spin out on accident.
Old Sep 8, 2008 | 02:33 PM
Riptide's Avatar
Riptide
If the road is slick it doesn't take driving like a maniac for the rear end to slide out. Not IME with the stock suspension and tires. I've even had the car fishtail a little bit going around a corner on dry pavement. It was uneven pavement and caused the rear to hop a little which, combined with the fact I had some throttle applied, made it to happen.
Neither incident came close to a wreck but it did make me respect the car more. After that I was a lot more cautious about how I applied throttle in turns.
Old Sep 8, 2008 | 03:44 PM
whtcanbrwnd04u's Avatar
whtcanbrwnd04u
Default puss
On dry pavement its kind of hard to whip the back out. I drove my friends stock gt and i tried it and it takes some throttle.
Old Sep 9, 2008 | 03:31 PM
05xgt's Avatar
05xgt
How bout using a little caution in bad weather? Would you speed on ice? Or in snow? Driver Ed 101
Old Sep 9, 2008 | 04:45 PM
SikO7GT's Avatar
SikO7GT
Ive tried out the TCS too in the snow and rain and if your tires spin the TCS light will flash and the throttle will go down on its own!! You must be really really stepping on it when in the rain!! Just take it easy man and u wont have a problem!!
Old Sep 9, 2008 | 05:47 PM
VistaGT's Avatar
VistaGT
Originally Posted by MustangGT0405
There is no reason to spin the tires in the rain at all. I am making tons of torque from 2000rpms and up and I have never once spun the tires in the rain by accident. And just for reference I am still on the stock 235/55/17 perilli's.
Not to bash anyone, but I think you need to practice shifting smoothly and applying the throttle slower.
Tires will certainly help, but mostly just focus on being smooth. Your best traction control is between your ears.
Drive Safe.
You run stock tires??? How do you EVER get traction?
Old Sep 9, 2008 | 05:53 PM
grampa_stang's Avatar
grampa_stang
TCS works (I've also tested it in the rain/snow). In foul weather, leave it ON.
Old Sep 9, 2008 | 05:54 PM
Derf00's Avatar
Derf00
Gentleman's Relish
really???? Never had any problems in my auto. What gear are you in when you goose it in the turn?
Old Sep 9, 2008 | 06:02 PM
Rubrignitz's Avatar
Rubrignitz
I have BFG KDW2 275/35-20's on my rears and have NEVER had a problem in the rain. These cars have limited-slip and I would have to really WANT to get the rear end loose, even in the wet! I've had trucks with open-diffs and couldn't stand it. I've had either a LS or locker rear installed in all my trucks. IMO, with either of those installed, you don't need TCS.
