350Z seats in a Mustang?
How feasible would it be to put 350Z seats in a mustang? They are shaped and bolstered like a Recaro, and arent marked in anyway I can see as being from a Nissan.
I would think I should be able to find 2 black seats someone else took out for upgrades, or ones out of a wrecked car.
What would I need to mount them?
I rented a 350Z the last time I was in CA and I really like the seats, the car wasnt bad either really.
Thanks for the input.
this is kind of a 'duh' statement (on my part), but look to see if there are mounting guidelines (distance apart from mounting screws, for example) for the 350 seats and compare them with your mustang's (i have no idea where to find that info, though; check with a nissan dealer, maybe). there is always the possibility they could bolt right on the base. that style of seat would look pretty good, imo
I've mounted a set of seats in a vehicle they did not belong in, it really isn't that hard as long as you have the right tools and a bit of time to check and recheck your measurements. What I did was remove the seat from the frame to make it easier to move in and out. I then bolted the one hole that happened be in about the right place w/ the new seat and just took measurements of the rest. Welding the new tabs you made on the existing frame is probably the best idea but w/o a welder I just bolted them to the existing tab and bolted that to the floor.
I guess it depends on the level of detail and finish you want, I suck and have little patience for finish work so it usually turns out functional but not so pretty.
i agree with eagle stroker... "ridemyassoff".. your a jackass.. that is what brings his car to a new level, and keeps yours on the one that its on.. that would be custom as fck, and look immaculate if done right..
i would be intrested if it doesnt fck with anything like seat belts, airbags, etc..
ford could have done a helllll of a lot better on these freakin seats.. its rediculous.. i feel like they are from an 88 ford ranger.. but i guess they do look pretty retro.. but whatever..
great idea OP! keep us posted!
Glad i'm not the only one that felt that way. No room or patience for classless people around here - that being said sorry for thread jacking lol. I'd be willing to try this if you found some seats on the cheap
I've been seriously considering putting new carpet in my car, feel the quality from Ford just isn't really there
