Engine Problems
Old Sep 21, 2008 | 03:25 PM
lbballin9's Avatar
lbballin9
Default Engine Problems
Pretty much every other time I drive my car the failsafe engine mode turns on. I heard today that it's because of a major malfunction with the car and instead of turning off it allows you to finish the drive to a dealership. Is this true? Could it maybe be because the guy who had the car before might have had it chipped and it isn't working with my mods? Any ideas would be greatly appreciated
Old Sep 21, 2008 | 03:37 PM
hammeron's Avatar
hammeron
yes, that's true
yes, this is also a possibility. if it were my car, i would
order a SCT Xcal2 tuner, with a custom tune written for
the mods on the car.
this way, at least you know the tune is right and if engine
failsafe persists, you can start looking elsewhere for the
culprit.
Old Sep 21, 2008 | 04:42 PM
TOMBSTANG's Avatar
TOMBSTANG
yes, that's true
culprit.
+1 what he said, get a tuner like the x-cal ansd just run it and see what codes come up then problem solved almost, well atleast u will know what the problem is from the codes.
Old Sep 21, 2008 | 06:46 PM
lbballin9's Avatar
lbballin9
I have an xcal 2...should I just order a special tune for it?
Old Sep 21, 2008 | 06:52 PM
hammeron's Avatar
hammeron
i would say yes.
for the PCM code, use the strategy code you
can pull with the xcal2
Old Sep 21, 2008 | 07:00 PM
DRFtstang's Avatar
DRFtstang
WELL IN MY CASE I HAD THE FAILSAFEENGINEMODE ON SO BAD THAT I HAD TO TAKE THE CAR HOME IN A TOW TRUCK THE CAR STARTED AND 3 SECONDS LATER IT TURNED OFF BECAUSE OF THE FAILBLAHBLAHBLAH. SO I PLUGED IN MY SCT & THE CAR STARTED TROWING LIKE 4 TO FIVE CODES. NON RELATED TO ANYTHING SOME OF THEM WHERE THAT THE FAIL SAFE ENGINE MODE CAUSED IT SELF TO PROTECT THE CAR BUT IN CONCLUSION AFTER 2 DAYS LOOKING TO WHAT IT WAS A FRIEND OF MINE LENDED ME HIS TROTTLEBODY AND VOALA. IT STARTED WORKING FINE. LONG STORY SHORT THE CAR TREW LIKE 5 CODES NON RELATED TO THE PROBLEM THE CAR HAD. IT HAD A BAD TPS, WENT TO THE LOCAL FORD PARTS STORE AND PICKED UP A NEW TPS. CAR IS NOW PERFECT AGAIN. YOU SHUOLD CHECK IN TO THAT.
Old Sep 21, 2008 | 07:05 PM
billyjo's Avatar
billyjo
first off make sure your MAF sensor is plugged in correctly. if the system does not read a single it puts into sage mode. also safe mode is made so you can get to the side of the road with minimal damage and only allows second gear in autos and only 15 t 20 mph. keeps revs low to. but if you do have a problem dont run to long on safe mode also if a tune was left in your cars pcm you will need the unit that was used for example a sct tuner, it holds the stock setting and can only be used with the car that its has the stock setting for. if your car has a tune and you dont have the tuner you can not upload a new program you will need to get a whole new pcm. good luck
Old Sep 21, 2008 | 07:44 PM
hammeron's Avatar
hammeron
if he bought a brand new xcal and went
to upload a custom tune, wouldn't the
xcal just save the current tune as the
stock tune?
i could be wrong, but that's how i always
thought it would play out, in that situation
new pcm. good luck
Old Sep 21, 2008 | 09:36 PM
Shard Phoenix's Avatar
Shard Phoenix
Could be the improper tune for the K+N, people have had problems with it when the vehicle isnt tuned for it... even though it claims no tune required.
Old Sep 21, 2008 | 10:06 PM
TOMBSTANG's Avatar
TOMBSTANG
ya I had similar problem and car went into fail safe mode and it was my throttle body sensor and the car would just idle radically. I ran my x-cal and it told me basically what it was.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
