A little help...
Old May 19, 2005 | 06:24 PM
mvp12's Avatar
mvp12
Default A little help...
Do these look funny to anyone? Are knockoffs necessarily of lesser quality? Im thinking of picking these up, if you have any advice it would be much appreciated.
Thanks...
Click Here
Old May 19, 2005 | 06:36 PM
don_w's Avatar
don_w
I ♥ Acer
Default RE: A little help...
I would look around some. When I was pricing out chrome bullits, I found them cheaper at a couple other sites than they were at customwheelsmarket.
Old May 20, 2005 | 01:57 AM
Redfire's Avatar
Redfire
Ive seen sets of these and other finishes in the Mustang car magazines. Black, Chrome, "Arizona Beige", etc. It pays to shop around.
Old May 20, 2005 | 02:22 AM
hawgman's Avatar
hawgman
I ♥ Acer
I got the same wheels from OE Distributors off of fleabay for about half that price.
Old May 20, 2005 | 03:59 AM
Scaught's Avatar
Scaught
A few hours spent shopping will save you "ONE MILLLLION DOLLARS!". Ok, not that much but a couple hundie you could put into something else...
Old May 20, 2005 | 03:58 PM
lostsoul's Avatar
lostsoul
anyone got links to the same wheels cheaper? I'm looking at them too now since I cant fit 275 good on the stocks =-(.. dont anyone know whats the max you can get on an 18x8 wheel?.. thanks
Old May 20, 2005 | 04:10 PM
don_w's Avatar
don_w
I ♥ Acer
ORIGINAL: lostsoul
Same width as a 17x8... probably 255s.
Old May 20, 2005 | 07:13 PM
lostsoul's Avatar
lostsoul
ahahha.. my bad.. 18x9 s... come on done.. you know my typing and spelling... you know what I meant .. those rims look nic and if I'm going over 450hp.. I think I need mroe then 235s.. if someone has a link to the same wheels for cheaper.. SAVE ME $$$
Old May 20, 2005 | 07:38 PM
don_w's Avatar
don_w
I ♥ Acer
ORIGINAL: lostsoul
ahahha.. my bad.. 18x9 s... come on don.. you know my typing and spelling... you know what I meant .. those rims look nic and if I'm going over 450hp.. I think I need more then 235s.. if someone has a link to the same wheels for cheaper.. SAVE ME $$$
lostsoul... one question: Why 18s? If you are going to have 450hp, I guarantee you are going to have trouble finding good 18" tires to handle the hp. That's why I went to 17s.
I knew my SC wasn't far down the road, and I couldn't find a 18" tire that was both wider and taller than the stock 235/55s. I was looking for a 285/45-18... no luck. I did find a 295/45-18, but it needs a 10" wheel (and I never found an 18x10 chrome bullitt with the correct 2005 offset).
With that much hp, you surely don't want a shorter tire... right? A 285/40-18 and a 275/40-18 are both shorter than the stock tire. And, you may need an 18x10 wheel for the 285s (but an 18x9 would probably work). Also, for traction, you'll probably want some sidewall height... 40s are thinner than stock, too.
Hey, it's your car, pal... but think about this. What good is 450hp if you can't plant it??
Old May 20, 2005 | 08:49 PM
mvp12's Avatar
mvp12
OK...maybe I left my original call for help a little too open ended...
Has anyone purchased black Bullitt wheels for an 05 mustang in 18X9 with approximately 36mm offset?
If so, from where and do you have a picture of how they look?
Thanks...
mark
