how bad 20's effect mpgs
I can't tell you from experience, because I still have the stock 17" wheels, but when you go to a big shiny 20" chrome wheel, you add a lot of weight. Weight is bad for fuel economy and performance no matter where you put it, and the wheels are one of the worst places to gain weight. The heavier wheels require more force in order to spin at the same speed as a lighter wheel, therefore a car with the same power will be faster with lighter wheels than if it had heavier wheels. The 20" wheels really kill your drag times because in order to get a good launch, you want a lot of tire sidewall. The smaller the wheels you have, the more sidewall you have (assuming you keep the same tire diameter). You want sidewall because then your tires can flex on launch and wont spin, therefore lowering your time.
well i have a truck with much bigger tires and rims and there alot heavyer so it does hurt me alot, and it takes more power to turn them. so it depends on weight and it also depends on your gears
i just got 20s installed today, when i was driving home the tire pressure monitor went off.
Can this be fixed, or do i just have to deal with this.
sorry for hijacking didnt think it was worth starting a new thread.
