Door handle question
Old Sep 29, 2008 | 08:34 PM
Mustangs4U's Avatar
Mustangs4U
Default Door handle question
I am not sure if anyone else is having this problem, but both door handles on my car stick out when the door is closed. Its like the spring or something doesn't retract the handle back in the door. Any ideas on what it would take to fix it? Any help would be greatly appreciated!
Old Sep 29, 2008 | 08:49 PM
Lethaldosage423's Avatar
Lethaldosage423
I have the same problem. if i pull the handle lightly it sticks out a bit. I dont know how to fix it, but hopefully someone on here does!
Old Sep 29, 2008 | 08:59 PM
snooj's Avatar
snooj
My first mustang (in the sig below) had that problem. I just took it to the dealership and they replaced the door handle. Warranty covered it so it was free.
Old Sep 29, 2008 | 09:01 PM
Mustangs4U's Avatar
Mustangs4U
Yeah, would be nice. At least I know I'm not the only one.
Old Sep 29, 2008 | 09:02 PM
Mustangs4U's Avatar
Mustangs4U
Hmmm, I just missed my warranty. Oh well, I'll find someway to fix it!
Old Sep 29, 2008 | 09:08 PM
Lethaldosage423
lol im way out of warranty, I was going to take off the door panel and see if there was a loose screw. it was a lot worse so i put some good old WD 40 on it.
if you figure it out, let me know!
Old Sep 30, 2008 | 06:02 AM
partsbill's Avatar
partsbill
Some 2005-2008 Mustang vehicles may exhibit an exterior door handle not flush in the closed position. This may result in a loose handle, rattle noise, hard to open, and/or door self locks when opening outside handle. (Figure 1)
1. Raise the door window glass to the full up position.
2. Remove the door trim panel.
3. Position the watershield aside.
4. Raise the manual lock rod to the unlock position. (Figure 2)
5. Disconnect the exterior door handle actuating rod from the front door latch assembly.
Open the retaining clip and disconnect the actuating rod. (Figures 3 through 5)
6. Reinstall the exterior door handle actuating rod back into the clip.
NOTE: DO NOT PUSH PIN BACK INTO HANDLE. (FIGURE 6)
a. Position the actuating rod into clip in a neutral or bias up position.
b. Close the retaining clip and test the system to ensure that the exterior door handle is operating correctly
c. Adjust the actuating rod as necessary.
NOTE: DO NOT BIAS THE ROD DOWN AND DO NOT BIAS THE FRONT DOOR LATCH.
NOTE: IF EXTERIOR DOOR HANDLE IS BROKEN, OR THE METAL PIN IS PULLED OUT OF THE SPRING ON THE BACK OF THE DOOR HANDLE, THEN REPLACE THE DOOR HANDLE
7. Position back the watershield.
8. Install the door trim panel.
Attached Thumbnails Door handle question-handle.gif   Door handle question-fig-2.jpg   Door handle question-fig-3.jpg   Door handle question-fig-4.jpg   Door handle question-fig-5.gif
Old Sep 30, 2008 | 06:03 AM
partsbill's Avatar
partsbill
continued from above post
Old Sep 30, 2008 | 06:51 AM
pascal's Avatar
pascal
S197 Section Modder-ator
Mine are tight as a virgin...
06, 33K miles.
Old Sep 30, 2008 | 07:16 AM
06elnr's Avatar
06elnr
I think I still have mine so if any of you have a silver car I maybe able to help you, pm me if you are interested.
