need help on lca's
Old Oct 7, 2008 | 08:41 PM
1morepart's Avatar
1morepart
Question need help on lca's
tb's write up:Re-attach Parking Brake cable and retaining clip. Tie wrap cable to side of LCA.
why is it necessary to undo the brake cable? what tie wrap are they talking about?
i am just installing the bmr lca
please advise
jason
Old Oct 7, 2008 | 08:54 PM
DarkFireGT's Avatar
DarkFireGT
I was going to get your PM, but I'll reply here instead.
The parking brake cable is routed through the opening in the stock LCA. It's required to detach the parking brake cable from where it mounts to the caliper to pull the LCA out. To remove, there is a c clip 1-2" below the end of the parking brake cable, which holds it to the caliper and keeps it from moving when the parking brake is engaged. Make sure you do not have the parking brake engaged. Pull that clip out with a park of pliers. Now pull the cable out of the holder, where it was being held in with the clip. This will allow you to unhook the parking brake cable.
You don't have to tie the cable to your LCA's, but it's a good idea. I didn't for quite some time and never had any problems. The ties TacoBill was talking about are just simple cable ties, or "zip ties". If you're using the BMR LCA's, you'll need long ones, or you can join 2 together.
Old Oct 7, 2008 | 08:58 PM
1morepart's Avatar
1morepart
thanks.......please show me a pic of these "ties"
Old Oct 7, 2008 | 09:26 PM
ErcWrestlr's Avatar
ErcWrestlr
Well said DarkFireGT. I used 2 "zipties" to attach the brake cable to the LCA. It just dangles there if not. Go to any home improvement, autoparts store, or wal-mart and you can find "zipties".
Old Oct 7, 2008 | 10:39 PM
DarkFireGT's Avatar
DarkFireGT
Old Oct 7, 2008 | 10:46 PM
1morepart's Avatar
1morepart
gotcha,,,thanks everyone
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Sep 30, 2015 10:13 AM
FivePointToTheOh
Sep 15, 2015 08:15 AM
JonnyBlazeGT
Aug 9, 2015 10:19 AM
