Experiencing some major hesitation.
I just noticed this about a week ago. It only happens like when I go from like less than 1/4throttle to full throttle. Also when I rev it a little from idle there is a very noticable hesitation before the rpms raise. I know I am giving a pretty vauge description but I am just confused at to what it could be. Anyone?
a suggestion is to reload your tune and see if clearing you Keep alive memory KAM helps. Another way is to turn you key on but dont have your engine running and push down all the way with your gas pedal for 5 seconds and then back up for 5 seconds this also clears your memory if that doesnt work you may need a new TPS due to a worn spot on the material
Omgitsa88Stang
10-05-2015 07:33 AM
Seanam
10-04-2015 10:15 AM
treesloth
09-28-2015 07:03 AM
