S197 minor problems.
Old Oct 10, 2008 | 08:56 PM
volcomchester18's Avatar
volcomchester18
Default S197 minor problems.
First I got to say she has 30k miles, runs very good, very happy with it. Only thing is, there is a lot of little things that need to be fixed when I take it to ford. You guys have any similar problems to these???
1. Light switch stiff to operate.
2. Insulation shows where you look at the vin form the outside.
3. Insulation for outside weather stripping shows.
4. Drivers window make a small squeeking noise. ( It also doesnt come down all the way sometimes, 1/4 inch sticks out).
5. One of the speakers makes noise.
6. When cruising in the freeway, heat comes in through the vents.
7. braking from high speeds, grinding feel and noise from front brakes.
Since its a new model, I guess this is normal. Its been really reliable, just these little things are well a little annoying. lol
Old Oct 10, 2008 | 10:09 PM
CobraO's Avatar
CobraO
Some of that stuff is pretty typical, especially for a domestic muscle car. I noticed the same thing as your #6. Heat coming in from the floor.
Most of those things they should address under warranty, better chance if you have a cool dealer.
Old Oct 10, 2008 | 10:11 PM
volcomchester18
^^ yeah my dealer is awesome, very helpfull. Yeah I know its common, especially for a completely re-designed model, but I was just wondering how many people have similar problems.
Old Oct 10, 2008 | 10:25 PM
Riptide's Avatar
Riptide
Yeah these cars seem to have their fair share of little problems. I've got insulation poking out from the trim on the driver's side door. Getting a rattle/noise out of a rear speaker. Some rattles coming from other parts of the car. Had to have the fuel pump TSB performed. Also have front end thunk from the strut mounts but haven't done anything about it.
Still like the car though.
Old Oct 10, 2008 | 10:33 PM
volcomchester18
^^^ yeah I love it too. Other car companies have small little problems too. I think most of us are picky too, cause most people dont pay attention to small little squeeks and rattles. Hell its not a 100k car. Funny thing, I got a ride in a new maserati and i found a rattle, LOL
Old Oct 10, 2008 | 10:46 PM
SirKnightTG's Avatar
SirKnightTG
Hey I have the heat coming from the vents when the windows are down issue too! It's so annoying. I usually have to turn on the fan and set it to vents (and cool temp setting but NOT A/C) to stop it.
I may ask my dealer about it next time I go in for an oil change.
johnnyv8's Avatar
johnnyv8
Ya, I've had a ton of small problems. However, my motor and tran has been like a built...
Old Oct 11, 2008 | 11:38 PM
doode's Avatar
doode
1. Light switch stiff to operate. nope
2. Insulation shows where you look at the vin form the outside. yes
3. Insulation for outside weather stripping shows. nope
4. Drivers window make a small squeeking noise. ( It also doesnt come down all the way sometimes, 1/4 inch sticks out).doesnt squeak, but mine doesnt drop all the way either
5. One of the speakers makes noise. probably loose wire or blown speaker
6. When cruising in the freeway, heat comes in through the vents.especially out of the tranny tunnel, but i can deal with it
7. braking from high speeds, grinding feel and noise from front brakes. you probably need new brakes
all normal
Old Oct 11, 2008 | 11:57 PM
07BLACKGT's Avatar
07BLACKGT
I have that problem as well and I took it in to get new brakes. The guys looked at it (Ford dealer) and said the brakes looked fine and it's just the ABS system that does that... It's beyond me why the ABS system would be making a grinding noise/feel with high speed light braking (mostly going down mountains)
Now I'm thinking it's hotspots from autocrossing.
Old Oct 12, 2008 | 12:33 AM
Bmr4life's Avatar
Bmr4life
The inside of my car rattles like crazy over the slightest bumps in the road. Anyone have a fix for this?
