Attaching 1/4 window louvers, which adhesive?
I just picked up some saleen 1/4 window cover and the way they are designed, 2 sided tape is going to be pretty tricky. I've talked to a few others with these same louvers and they have said that 3m probably isnt the best route. Whats a good adhesive i could use that wont damage the paint? I'm thinking something like clear rtv silicone or some sort of caulking, liquid nails, etc?
It would help if you post a few pics of the backside of the louver. Will it attach to the glass or body? Without seeing anything, I'd still have to say 3M tape. Besides being proven, its highly configurable. I doubt those other items you mentioned would hold up over the course of time.
Glad to see more PSU fans here. My oldest son and I are alumni...
I wish I was alumni, I got accepted for graphic design but missed a deadline so had to wait until the following fall to start so i joined the Air Force. I am a PA native though
This is the groove area that Nate refers to. The outside groove rests on the paint of the car, the raised lip sits inside the groove separating the window and paint, and the inside groove is made for the adhesive.....
I personally used welders contact cement, as the contact was strictly on glass, not paint....
Nate, go to this link, then go to parts, and do a search on quarter window louvers. There is a pdf on the instructions....I would suggest maybe just going by a glass shop, and seeing if they could hook you up with the suggested adhesive.....
Mike
http://www.saleen.com/default.asp
Mike
Mike, will do. I'll probably just use what you used. Where did you get it?
ok so looking at the instructions, did they put the tape on the glass then glue the louver to the tape?
Nice! I never knew that.
I'm a Junior in Electrical Engineering at University Park.
Are you coming to main campus next year?
