Took a few pics of the No2 Install and
#23
#25
Nice and clean. Glad to see you did everything the right way. Blowdown tube, blanket etc. Nitrous is a great mod and very safe when you do it right. I have freinds who just want the base kit and go. I always try and sway them to a window switch blanket, remote bottle opener etc.
Is that stuff required no, but it really helps the system/safety/and ease of use.
#27
that's a very good and clean install! i'm FINALLY going to mount my bottle tomorrow since i don't think i can get past tech at the track with it sitting inbetween my passenger seat and the rear seats..haha i might steal your idea on where you mounted yours. maybe even clean my wiring up a little as well while i'm at it. i tried spraying on the street and it didn't work. haha didn't hook up til third gear with my 4.10's. i did try it with my drag radials once after the track on the street and it worked pretty damn good off the launch too like at the track. enjoy the spray.
#30
my ZEX kit is setup very similar and the bottle is actually mounted wrong, but i think we both wanted it to look better. the neck of the bottle is supposed to be facing the front of the car. reasoning is that nitrous works like water when forces act upon it. when the car accelerates, the nitrous moves the rear most part of the tank. the pickup tube is at the bottom and more towards the center of the tank. so when the nitrous flows away from the pickup, your not getting all the available nitrous for spraying.
like i said, mine is installed the same way and i was informed by a member on another forum and it makes sense. im not trying to bash up your thread. it is a very clean install with all the essential components to spray safely
