Kenwood dnx5120 install help
Tried the audio section but it aint getting much traffic so I will try here. Bought this headunit the other day to replace my Shaker 500 and will be here in a couple of days. In the mean time trying to put together a list of items will need for the install. I know I will need to get the dash install kit and ipod cable. Do I need to get a wiring harness and/or a volt regulator for this type of headunit. I have read the installs for the D3 and was wondering how closely can just follow that install since not much info on the dnx5120 direct install.
you will need a volt regulator and a wiring harness. Dont use the mounting kit faceplate though. The kenwood comes with a plate that matches the mustang perfectly and looks way better. Also I used a transistor instead of a voltage regulator, I just attached it to the main power cable and it works great. The radio is really a great radio and you will be sooo happy with how it looks.
My Car=
My Car=
Is there a big difference between the kenwood one and the ford one??
How close can I follow this install?
https://mustangforums.com/forum/2005-2014-mustangs/394366-avic-d3-installation-56k-go-away.html
Thats a good tutorial and you can honestly still use the ford mounting faceplate. I just like the kenwood one because it matches the mustangs interior so perfectly(but there is a small gap as you can tell in the pictures) Both mounting faces will work great
