rear end strengthening?
Old Nov 12, 2008 | 03:34 AM
Hufenstang's Avatar
Hufenstang
Default rear end strengthening?
So i have my last batch of mods about to go in and was wondering if anyone else is using any of this stuff and if you have any tips during install. The boost a pump and 2 step are already installed in the picture. I have a detroit tru trac, LPW low profile cover, arp studs, and a che rear brace, also have a bottle of friction modifier.
Just wondering if theres anything i should watch out for in the install this weekend.
Thanks
Old Nov 12, 2008 | 05:23 AM
Stkjock's Avatar
Stkjock
Retired Mod
truetrac's dont use the modifier
Old Nov 12, 2008 | 05:38 AM
Hufenstang's Avatar
Hufenstang
oh, good to know! Thanks for the tip.
Old Nov 12, 2008 | 08:12 AM
MustangGT0405's Avatar
MustangGT0405
Are you also doing a new set of gears?
Also why are you doing the CHE brace? I havent done anything to the pumpkin yet, but I have planned 4.10's or 3.73's, Tru Trac, and Girdle.
CHE brace looking interesting though.
Thanks,
Old Nov 12, 2008 | 11:07 AM
SirKnightTG's Avatar
SirKnightTG
What exactly does the tru trac do?
Old Nov 12, 2008 | 11:16 AM
bolivianpimp's Avatar
bolivianpimp
I know nothing about what your doing Hufen, but i want to see it at the track! Let me know when you are planning on going.
Old Nov 12, 2008 | 11:55 AM
MustangGT0405
Stock our cars have a Trac Lock LSD, that uses clutchs. These clutches wear out over time and the car becomes a one tire fryer.
A tru trac doesnt use clutchs so it is stronger.
Old Nov 12, 2008 | 02:37 PM
TJ's Avatar
TJ
Thanks
Huf with your car being a manual and at your power level (from the bits and pieces Ive caught aleast 550+rwhp??) I would put in a set of hardened 31 spline axles while you have apart without a doubt imo. A decent set will cost around $350.00. I would also seriously think about the the GT 500 fuel system at that power level.
Hey could you post a list of what you have done to your car?
Old Nov 12, 2008 | 02:55 PM
Hufenstang's Avatar
Hufenstang
Oh i already have the gt500 fuel system in, i maxed the stock one out awhile back!
Give me a minute ill post my list, its on my laptop.
Old Nov 12, 2008 | 03:05 PM
Hufenstang's Avatar
Hufenstang
okay here is my list.. The cars at the shop. It was getting tuned for the cams, but then i found out my supershaker was finally shipped so i had them stop and wait for it to come in so i wouldnt have to pay twice for a tune.
Black 2005 mustang GT purchased march 14, 2005
Engine
- Saleen SuperShaker Supercharger
- 298 Forged Stroker Motor
- Manley 9.0:1 Custom JDM Pistons
- Manley H-beam forged steel connecting rods
- ARP Main studs
- Kellog 8 bolt forged steel stroker crank
- JDM Custom Ring pack
- GT-500 Oil Pump
- Manley Springs AND Titanium retainers
- Stage 2 Comp blower cams SPR
- Cam Phaser limiters
- Custom Motor mounts
- Custom 8 rib belt kit
- Afco dual pass heat exchanger
- Fluidyne Radiator
- bosch racing aftermarket intercooler pump
- Meziere Electric water pump
- 60 lb/hr fuel injectors
- Thumpr pulley Tensioner
- gt500 fuel pumps
- Fore precision fuel rails
- Bigger upgrade fuel lines
- Fore precision triple pump fuel hat
- KB dual boost a pump competition series 1000hp rated
- SCT tuner with 93 octane/e85/ and vallet tunes
- 2.8/3.2 supercharger pullies with 10% overdrive pulley (16.5psi/10.5psi)
- ht0 spark plugs
- Canton coolant expansion tank
- Custom Oil seperator
- New up to date cam phasers
Transmission
- Tremec tr6060 - 6 speed manual
- Custom lightweight driveshift
- Pro 5.0 shifter
- Custom shift ****
- Spec 3+ clutch 26 spline disc
- Spec steel flywheel 8 bolt
- SLP Line locks
- msd launch master 2 step
Rearend
- 4.10 Ford polished gears
- Eaton Detroit True-Trac 8.8" 31 Spline Limited Slip Differential
- BMR Front drive shaft loop
- LPW low profile girdle
- CHE axle brace
- Custom welding job
Exhaust
- JBA Longtube Headers Ceramic Coated
- Custom Cut H pipe
- Welded in High flow performance Catalytic converters (supports up to 1000hp without crumbling)
- Ford FRPP Stingers axlebacks
Suspension
- Steeda Billet lower control arms
- Steeda Adjustable upper control arm
- Steeda weld-in Lower control arm relocation brackets
- BMR adjustable Panhard rod
- BMR Panhard Rod brace support
- Steeda street heavy duty upper strut mounts / heavy duty caster camber plates
- Steeda Ultralite Lowering Springs
- Tokico D-Spec Adjustable Shocks
Brakes
- Hawk brake pads
- Steel Braided lines
Tires
- BFG KDW 2's (street tires)
- MT ET STREETS (track tires) on bullit wheels
Interior
- Speed of sound A pillar 2 gauge pod
- Speed of sound 3 gauge radio pod
- Dual Aeroforce interceptors
- Roush A/C gauge pod
- Autometer cobalt series Electric boost gauge
- Autometer cobalt series Electric Oil presure gauge
- Autometer cobalt series Electric Fuel pressure gauge
- Autometer Wideband Air/fuel gauge
- Custom shift boot and ****
