Strange noise
Old Nov 28, 2008 | 05:53 AM
CrazyHorse0217's Avatar
CrazyHorse0217
Default Strange noise
I'm getting a strange noise that sounds almost like mild power steering groan when my car is idling. It only does it when the a/c comprssor cycles on and my car is in gear (automatic), causing the rpm to drop around 500 or 600 rpm. Sounds like maybe a bearing, but the noise goes away over 600 rpm.
Anyone ever encountered this? I can have my tuner bump up the rpm's, but I would rather isolate the problem.
Thanks.
Old Nov 28, 2008 | 09:37 AM
157dB's Avatar
157dB
Cut & Paste Expert
Thanks.
Check your belt tensioner for slop or improper alignment from wear.
I get a chirp right after the starter disengages when I start my
stang in the cold morning hours. Belt squeek, it sounds like.
Just a slight chirp now that its cold out. And just on that first
start of the morning. Any ideas (hijack).
bjdutch2005
Mar 24, 2017 03:38 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
KingRando
Oct 2, 2015 08:06 AM
Emblazoned
Sep 3, 2015 10:45 PM
