Sponsored by:
Sponsored by:
problem with emissions check for inspection
Old 11-28-2008, 03:31 PM
surfbum7190
surfbum7190's Avatar
Default problem with emissions check for inspection
i took my car in completely stock besides my intake/tune and everyyhing passed, but they could not run the tests for the emissions because they said the cars computer would not allow them to. i automatically thought it was the tune, so i loaded the stock tune on, drove the car for about a week and then took it back. same problem occured. anyone know what could be wrong?
surfbum7190 is offline
Old 11-28-2008, 05:23 PM
Lethaldosage423
Lethaldosage423's Avatar
I see in your sig, No Cats, no muffler, that may be a problem
Lethaldosage423 is offline
Old 11-28-2008, 09:23 PM
mustangman02232
mustangman02232's Avatar
are you sure the stock tune uploaded?
mustangman02232 is offline
Old 11-29-2008, 07:20 AM
Flatline1980
Flatline1980's Avatar
I'm a happy camper i don't have to worry about emissions.. I'd guess its not having any mufflers..
Flatline1980 is offline
Old 11-29-2008, 08:35 AM
surfbum7190
im not an idiot i put my stock exhaust back on. everything about the car is stock now. My tuner still says i am running lean though and i am positive my stock tune loaded
Old 11-29-2008, 09:20 AM
howarmat
s197 Junkie
howarmat's Avatar
unplug battery for an hour, then the CEL should be gone, check all connections with the air intake and such. If the light comes back after that then you have bigger problems somewere
howarmat is offline
Old 11-29-2008, 09:43 AM
jmk3
jmk3's Avatar
Check the help files on Brenspeeds sight to see if you hooked the O2 sensors back up to the proper plugs, they criss cross & many have hooked them up backwards which confuses the ECM.
Hope it helps
jmk3 is offline
Old 11-29-2008, 12:46 PM
Lethaldosage423
Sorry dude lol
Old 11-29-2008, 01:10 PM
1morepart
1morepart's Avatar
Agreed!!!
1morepart is offline
Old 11-29-2008, 01:27 PM
Stoenr
Stoenr's Avatar
Pretty sure the rear o2's are the same, so swapping should not matter. And pretty sure they wont reach across to plug into the other side.
Its more than likely you have not completed the required drive cycle to get all the monitors ready. Its a pretty goofy drive cycle thats for sure.
Disconnecting the battery will only start that process over again.
Anytime you retune, or disconnect that battery, the cars monitors are reset and driving/idling cold/warm are required to get them ready again.
Read up
http://www.obdii.com/drivecycleford.html
Stoenr is offline
Quick Reply: problem with emissions check for inspection
