Help with mustang's odd behavior
Ok, my mustang's been stalling out on occassion lately, and i can't figure it out, and search is not help. Let me see if i can detail what happens, and my mods are listed in my sig...
My car will be acting normal, but all of a sudden, when i come to a stop or engage my clutch, my car dies. It always starts right up, but can't hold an idle and will die again unless i stay on the throttle a bit. Sometimes, when i restart, my info center will say "failsafe mode", but there are never any codes when i try to pull them. If i disonnect my battery, or simply reload my tune, it seems to fix the problem. This happens about once a month. It occurs on both my Brenspeed and Bama tunes. I've had my cai/tunes for like 9 months before this started to happen. i did change to an o/r midpipe, but i had it for several months before this happened.
I've already had the fuel pump TSB performed; i changed the fuel filter 12k miles ago; i've cleaned the MAF sensor lately; i've sloppily cleaned the throttle body, but haven't taken it off and done it well; my air element isn't spottless, but isn't too bad.
Thanks for any help you can provide!!
Yeah UT is awesome and ATM sucks... sorry, just a tad bitter after losing to ATM the last three years!!
I would HIGHLY recommend purchasing some MAF and TB cleaner. Remove the CAI, clean the MAF sensor and TB (opening the butterflies by hand and cleaning it VERY well). Even after 30k miles cleaning mine helped the idle a great deal.
