C&l Racer
Old Dec 2, 2008 | 10:47 PM
ZERO4572003's Avatar
ZERO4572003
Exclamation C&l Racer
Just wondering If My C&l racer intake will work with an off road xpipe and do u need a custom tune for it to work right or can u just edit the preloaded tunes that come with the tuner?
Old Dec 2, 2008 | 10:56 PM
Black3vGT's Avatar
Black3vGT
I think you can edit a custom tune and turn off the O2 sensors. If not you can still run around until you can get another tune, all that will happen is your check engine light will come on.
Or you can just buy some Mil Eliminators to turn off the check engine light.
Old Dec 2, 2008 | 11:15 PM
ZERO4572003
Question
Yeah i have turned my rear O2 sensors off and then changed the air box to the c&l racer intake then drove down the street then my car just cut off then i checked under the hood and my ignition fuse blew out then i replaced it blew out agian then i put the stock intake back on then it worked fine.
Old Dec 3, 2008 | 07:10 AM
1morepart's Avatar
1morepart
your c&l intake MUST be tuned or your car will keep doing the same thing or just not start!
when you get it tuned, because you will have too, have the tune shut off the rear o2 sensors........the untuned c&l is obviously the problem...tune it!!!
jason
Old Dec 3, 2008 | 09:49 AM
howarmat's Avatar
howarmat
s197 Junkie
the intake is not causing the ignition fuse to blow....something odd is going on here
Old Dec 3, 2008 | 12:46 PM
shanec's Avatar
shanec
My SCT tuner instructions say something about disconnecting fuses before loading a tune onto the car? Is that really neccessary? Could that be part of the problem here?
Old Dec 3, 2008 | 12:49 PM
howarmat's Avatar
howarmat
s197 Junkie
it could be, they have been many stories about fuses getting blown while trying to install the tune.
Old Dec 3, 2008 | 01:01 PM
ZERO4572003
Someone else told me that i should get new spark plugs and then it would run ok or there might be a short in my system somewhere.
Old Dec 3, 2008 | 01:03 PM
howarmat's Avatar
howarmat
s197 Junkie
if its the spark plugs its an unrelated incident. Again doubtful
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
Sep 15, 2015 07:34 PM
