Crankcase ventilation
Old Dec 4, 2008 | 05:16 PM
Rubrignitz's Avatar
Rubrignitz
Default Crankcase ventilation
Has anyone removed the stock valve-cover to intake crankcase vent lines and replaced with a filter-type?
I've seen folks hook up the "oil-collector" system but are these even required? I would think you could just plug the hole on the intake and replace the valve cover tube with a ventilated/filter top. Pics please if you've done this.
Old Dec 4, 2008 | 05:20 PM
xxDerek's Avatar
xxDerek
Why would you?
Old Dec 4, 2008 | 05:24 PM
wilkinda's Avatar
wilkinda
2010 Section Moderator
Originally Posted by xxDerek
Why would you?
+1 on the Why would you?
Old Dec 4, 2008 | 05:25 PM
Rubrignitz's Avatar
Rubrignitz
I dunno, why would someone devise an "oil separator system"? I was just wondering why they wouldn't just plug the intake hole and replace with a crankcase filter-cap.
Now that I'm thinking about it, that may cause a vacuum condition and/or CEL issue.
Just figured I'd post something I'm wondering about and what the consequences would be...
Old Dec 4, 2008 | 06:35 PM
Simon1's Avatar
Simon1
The reason for doing this is pretty good for some. The recirculation does a few things.
1. Recirculates warm air into your intake when your motor is cold, thus helping it warm up faster. It helps emissions by getting your car to operating temperature faster where it is most efficent.
2. Recirculates the "bad" vapors that would/could otherwise be vented to the atmosphere, burning them over and over again in the motor until they are expelled.
The bad thing is those vapors contain contaminants which are not good for the motor. People with FI do this because of the increased pressure with running boost into a motor. This lets extra or more oil go through the breathers coating the intake, thottle body and building up deposits of nastiness. There are more technical ways to describe it but I'm not a mechanic.
I would not put a breather directly on the cam cover spout opening. The reason for this is a mixture of gas/carbon/oil and other emissions emit from this thing. Just a beather will cause there to be a gooey mess down the side of your cam cover and maybe on the underside of your hood. The cheapest way to do it is get 4-5' of the same diameter tubing and two small breathers to go on the end of each hose. Run them to just behind the headlight and ziptie them in place. For guys with normal power levels running NA this doesn't seem to be needed but it won't hurt. For guys with any form of FI, they should have something done.
I didn't like the mess the breathers did so I put a little catch can (coke can cut in half) under the passenger side filter. It catches probably a teaspoon of fluid for each tank of fuel and alot of it evaporates as it comes out.
Old Dec 4, 2008 | 06:36 PM
Simon1's Avatar
Simon1
It won't cause a vaccuum or CEL issue.
Old Dec 4, 2008 | 06:57 PM
Rubrignitz's Avatar
Rubrignitz
Hmmm, good to know! I knew that the crankcase gases (blowby etc) couldn't be good for combustion but were mainly for emissions purposes (as you stated about the recycling of the gases). I was uncertain as to whether a CEL/vacuum issue would emerge but you cleared that up. Great info! thanks.
Old Dec 5, 2008 | 06:43 AM
GrayPony's Avatar
GrayPony
easy to make...here's mine. A must with FI
apicia
Jun 29, 2007 01:58 PM
BlueStang6
Jul 8, 2006 08:42 PM
flapjack
May 12, 2006 11:19 PM
Twisted
Apr 20, 2006 07:07 AM
fearthis8544
Jan 23, 2006 05:21 AM
