Whatever you do, my advice to you is don't go higher than 40 on profile-- you gonna hate your car's behavior over 100mph and if you drive that fast a lot you'll probably switch back to what you had
Thanks for that picture. I want to run 295/35/18s and was worried about the gap with the Pro-kit, but even with your shorter tire it still looks real good.
Hey there Owero01... I'm not ragg'n on you here because I think you have one heck of an awesome look'n ride there .....But, i'm just curious here ..!! So, assuming that you had the Eibach Pro's installed for not only better handling but to also fill-in your back wheel gap, why did you go to a much shorter tire (275/35/18) over your stock ones. Depending on what size your original stock tires were, you probaly lost around 2". Didn't you want to end up with even less rear wheel gap then you have now ?? Again, just curious....???
