Sponsored by:
Sponsored by:
Installed Brembo brakes, bleed the breaks and now the car won't start help!
Old 12-07-2008, 11:15 AM
CroDalmatinac
CroDalmatinac's Avatar
Default Installed Brembo brakes, bleed the breaks and now the car won't start help!
Problem has been fixed!
CroDalmatinac is offline
Old 12-07-2008, 12:37 PM
cobra443
cobra443's Avatar
You didnt post any pics!! Thats why it wont start! Other than that, I have no clue.
cobra443 is offline
Old 12-07-2008, 12:53 PM
CroDalmatinac
I'll post pictures after I can get it started haha.
Old 12-07-2008, 01:26 PM
302me
302me's Avatar
You didn't disconnect the battery for any reason did you. Other than that it sounds like just a coincidence to me.
302me is offline
Old 12-07-2008, 01:31 PM
Va. Stang
Va. Stang's Avatar
Prob. just a dead battery. Check the voltage then charge it!
Va. Stang is offline
Old 12-07-2008, 01:34 PM
CroDalmatinac
No I left the battery on. Thing is, it worked perfectly fine before I started the process. Now when I start the car, it just sounds like it wants to start but doesn't and the doors unlock and lock. Do you guys think disconnecting the battery for 15 mins and trying again might work?
Old 12-07-2008, 01:43 PM
One Bad Stang
One Bad Stang's Avatar
give it a shot. maybe it got weak while you were installing the brakes. but i can tell you with absolute confidence, your rotors wont kill your battery.
One Bad Stang is offline
Old 12-07-2008, 02:46 PM
hammeron
hammeron's Avatar
hey CroDalmatinac, is the engine cranking
over?
if yes, then check the inertial fuel cutoff switch
if no, then put the battery on a charger for a few hours
hammeron is offline
Old 12-07-2008, 02:57 PM
CroDalmatinac
Forgive me for my ignorance but do you mean the Fuel Pump Shut- Off Switch?
Old 12-07-2008, 03:24 PM
hammeron
hammeron's Avatar
yes, on the 05/06 it's near the drivers
left leg area
hammeron is offline
Quick Reply: Installed Brembo brakes, bleed the breaks and now the car won't start help!
