Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
- Ford Mustang V6 2005-2014: Why is My Car Leaking Inside?
Step by step instructions for do-it-yourself repairs.
Water Leaking Inside Car...Emergency!
#21
Thanks for the info on how to fix it. I just feel if it is a defect from the factor and my car is still under warranty, I shouldn't have to fix it. I've also found water in the junction box but so far it hasn't caused any electrical problems. I will see what the have to say tomorrow.
#22
#24
Open your web browser, goto mustang forum . com
search 'water leak' and read all about it.
Most all S197s leak under the glove box.
You SJB is the next item to short out.
#25
Update#3
Called the dealership today and they said their are still some parts missing that they order. Hopefully, the car will be done tomorrow. I also want to know what kind of parts they are replacing on the car.
#26
Probably the inadiquate or missing cowl mounting clips/hole sealers.
#27
FWIW
I found water laying in the passenger's footwell of my 05 S197 last winter after the car was out of warranty. Traced the leak back over the top of the white foam "water deflector" strip that's supposedly designed to protect the SJB from water leakage to an area above the SJB, but could not determine the exact point of entry. The first thing I checked were the 2 black rubber grommets in the firewall. They were clogged with leaves and other debris. I cleaned them out, but the water continued leaking into this same area. So I decided to initially address the issue w/o paying the dealer(or anyone else) to fix it. I thoroughly dried out everything with paper towels and a hairdryer. Pulled the bottom end of the white foam strip up and over the top of the black plastic barrier that covers the SJB, and taped it in place. Rolled up a few paper towels, and wedged them under the SJB plastic barrier directly below the white foam strip. Now when it rains the water flows down the white foam strip, and drips onto the paper towels, which sop up the water and prevent it from soaking into the carpet. I realize it's a Rube Goldberg setup, but it's an extremely inexpensive fix which requires very little effort on my part, and it's keeping the carpet dry and preventing mildew and it's sour odor from forming.
However, one thing that I discovered since last winter is that the paper towels stay bone dry when it rains once the ambient temperature increases into the mid 40's and above(There is also no leakage when I wash the car, which is done only when the temps are the 50's and above.). But once the temps fall below 45 or so, then the towels get wet. So now I check the towels for wetness only when it rains with the temps in the 40's and below.
My theory as to why this is happening is because the sealant is cracked in the seam that's located at the juncture of the A pillar, firewall, door, and fender on the passenger's side. This seam opens when the temps get cold due to the steel contracting, which then allows water from any exterior source to flow into the car's interior. The seam closes when the temps get warmer due to the steel expanding, which then prevents water from entering.
And since the cure for this problem requires more expertise than I have, I just make sure that I always have an adequate supply of paper towels.
#28
Update#4
Got the car back but it is not fixed. They told me after installing a bunch of new parts, it still leaks water. They have had to call Ford about this. They don't know when they will hear back, so they told me to come and get the car. This is an open ticket item now. I can't wait to hear what they are going to do next.
#29
Update#4
Dont let em blame it on your headers....
