Suspension Advice
Old Dec 11, 2008 | 11:07 AM
lbballin9's Avatar
lbballin9
Default Suspension Advice
Hey guys. I've already got some lca's that I need to put on my car, but I'm also wondering what else I should get for the suspension. Uca's? Subframe connectors? What else? And can I find either of those pieces for under 100 and have them still be good pieces? I found some uca's on rpmoutlet for under 100, but anything other ideas? Thanks!
Old Dec 11, 2008 | 11:14 AM
zporta's Avatar
zporta
springs shocks struts?...i was def lower that thing...and if u lower it u will need LCA relocation brackets...
Old Dec 11, 2008 | 11:17 AM
lbballin9's Avatar
lbballin9
I'm worried if I lower it, if I try to go over any speed bumps I will be screwed. Especially since my mid pipe hits a speed bump now when I go over one.
Old Dec 11, 2008 | 11:18 AM
zporta's Avatar
zporta
well how fast 2 u go over the speed bump? unless u have a cervinis side exhaust u shouldnt have a problem if u take it slow
Old Dec 11, 2008 | 11:23 AM
lbballin9's Avatar
lbballin9
z, for the struts, I see a lot of times people have to remove them when they get a supercharger put on. Do you know of any that I can use for now and when I get the sc on? Struts are supposed to keep your a$$ from sliding around right?
Old Dec 11, 2008 | 12:58 PM
tx_zstang's Avatar
tx_zstang
I'm still running stock struts with my supercharger, but not for long. The extra weight of the supercharger and intercooler has made my front end a little lower; adjusting for the weight change would be ideal if you can do it, but I dont think its absolutely needed.
But I'm putting on different springs/struts/shocks here shortly anyway, and will rebalance the car per its current weight distribution via the adjustable shocks/struts.
Struts dont keep you from sliding sideways; they work with the springs to maintain ride height and smooth out bumpiness.
Now, go get that bad boy blown!
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
