Steeda UDP installation
I just recieved the pulleys, read the directions. Now I would like to hear what the real installation experiences are. What to watch out for, or what to do different. I would appreciate any advice.
Thanks
Thanks
Yea Nuke's right. TB has a good install guide.
SOmething to watch out for, at least was a problem during my install was finding the right puller. I'm sure it wouldn't have been a problem if I checked but i didnt and it took 3 different pullers to finally get it off haha
Most small 3-jaw pullers will work on the damper. Not super hard to get off. You will also need to get a new bolt for the damper and use a torque wrench to reinstall. If you have a manual, put it in 4th gear while you are working on the damper.
Make a detailed drawing of the belt routing to get it back on correctly. I used some removable Loctite on the water pump bolts and the alternator bolt. A little sealer on the keyway and you have got it done.
Frank
09-10-2015 08:39 PM
09-08-2015 11:50 AM
09-02-2015 08:40 PM
