Has anyone removed tint?
get some 409 and a little soap in a squirt bottle with water and spray it all over the tint and let it sit for a couple minutes but constantly keep spraying it. then get a thin blade and gently scrape a corner to pull the tint off but make sure you keep spraying and keep it all moist, if not then its gonna pull apart in more then one piece
Yea I heard thats the way to do it. I used goo be gone and sat there for couple hours.
My friend took off his tint with a razor blade and rubbing alcohol. Be careful not to scratch the glass. 2 front windows took him 40mins. Just pay a tint shop to do it and save you the stress and possible scratched window.
there is a tint shop at the end of the street and i have seen them do it a lot...they spray the window down with there soap solution then use the razor 2 peel the edge up and pull slowly... afterwards re-wet the windows and use a razor blade and go over the whole window to remove all glue then wipe clean....maybe 5-10 min each side...
I took mine off by myself using tint remover spray from Checker auto parts. Took a few hours, but I think I went a lot slower than I needed too. Ask your local tint shop how much it would cost to have it removed. As the guys above have said, shouldn't be more than a few dollars.
I've read around here that vinegar is the trick. Maybe try to search that. If it's less than 40 bucks, let the pros do it.
jwog666
Dec 27, 2021 08:09 PM
