HELP HELP HELP!!!!
Old Jan 3, 2009 | 07:59 PM
kpaulhus's Avatar
kpaulhus
Default L/T Header HELP HELP HELP!!!!
I am literally in the middle of installing my L/T's and I unbolted the engine from the motor mounts and jacked up the motor almost 2 1/2 inches. THe damn motor mounts are stuck! Anyone got any ideas. I mean they are not touching the bolt you can see from the top of the engine but it seems like they are stuck to the engine. I removed 4 nuts from the mounts....am I missing something. I promise Ill post a clip tomorrow cuz i dont see this project going tooo late into the night....unless I cant get these damn mounts off.
EDIT: I am having a hard time removing the steering shaft to get the drivers side header in place. I bought a Haynes Manual but it says I need to remove the steering wheel and basically pull the entire column. Has anyone actully done this?
Old Jan 3, 2009 | 08:04 PM
deekum1627's Avatar
deekum1627
good luck man
Old Jan 3, 2009 | 08:07 PM
kpaulhus's Avatar
kpaulhus
has anyone done this or might know what to do? Im setting a record I think. Its only taken me an hour and a half to get this far lol on my back with jack stands by myself.
Old Jan 3, 2009 | 08:10 PM
aircare84's Avatar
aircare84
There is 1 stud & 3 bolts on the mounts, remove the nut, Then remove the stud.
I can't remember if there is 1 on each side, or just 1 on 1 mount.
Believe it was for a negative cable.
Old Jan 3, 2009 | 09:15 PM
bodyman's Avatar
bodyman
tap the mount with a hammer,sometimes the motor mount sticks to the block.
Old Jan 3, 2009 | 11:13 PM
One Bad Stang's Avatar
One Bad Stang
here's a detailed write-up on replacing motor mounts, make sure you got all the bolts.
https://mustangforums.com/forum/2005...-and-vids.html
Old Jan 4, 2009 | 12:08 AM
kpaulhus's Avatar
kpaulhus
I ended up losing my internet connection out back in the barn but I got more lighting and realized that there was another bolt on the front of both motor mounts. I got everything stock off the car in about 3 hours....with the 35 mins I tried to get the mounts off. Tomorrow I will get back at it and hopefully get this thing rolling again.
Old Jan 4, 2009 | 12:20 PM
kpaulhus's Avatar
kpaulhus
Any one got any ideas on how to get the Driver side header past the steering shaft?
Old Jan 4, 2009 | 12:26 PM
howarmat's Avatar
howarmat
s197 Junkie
you have to remove the steering shaft
Old Jan 4, 2009 | 12:38 PM
kpaulhus's Avatar
kpaulhus
I figured that. When Im under the car looking at it there is a swivle joint thing right about the power steering pump. I see on bolt that holds the shat to the swivle but nothing higher to remove the actual shaft? Is there another bolt more towards the fire wall that Im missing?
