New Mirror - Removal
Old Jan 4, 2009 | 03:23 PM
pat123's Avatar
pat123
Question New Mirror - Removal
Guy's; can anyone tell me how to remove the factory rearview mirror. I know that there is supposed to be a spring that you access from the bottom but I can't find it.
Old Jan 4, 2009 | 03:27 PM
howarmat's Avatar
howarmat
s197 Junkie
Carefully insert a screwdriver in the notch on the bottom and apply pressure up and out a little and it will come off
Old Jan 4, 2009 | 04:22 PM
pat123's Avatar
pat123
Thanks, I guess I just needed to play with it for a while. I have finally gotten it off and I am now installing the new AutoDimming; Temp; Compass; Homelink mirror.
Old Jan 4, 2009 | 04:40 PM
eddypython's Avatar
eddypython
My setup was different. I had to use two jeweler size flat tips and pry in the sides, and it came out really easy. I didn't have the notch like in the pic.. I guess Ford made different types or something because I looked online to find how to take it off and everyone talked about the notch lol.. good luck
Old Sep 13, 2009 | 04:29 PM
asci01's Avatar
asci01
I just took mine off. I put a little bit of WD-40 to help loosen it. Then I put a small screwdriver through the bottom opening of the mirror base. It should go in about 3/4". Then gently push the screwdriver up and pull towards you while at the same time pushing the mirror up and wiggling it side to side. It will come off then. Do this at your own risk though.
Old Sep 13, 2009 | 05:51 PM
Lethaldosage423's Avatar
Lethaldosage423
Where did you get this mirror and what did you pay?
Old Sep 14, 2009 | 08:07 PM
eddypython's Avatar
eddypython
http://motors.shop.ebay.com/lkqonlin...dkw=&_osacat=0
That's where I got mine from ( LKQ ) . It's a gentex had the autodim compass and temperature.
I had to buy the temp probe separately. there's a write up on how to do it. it's easy to do..
Old Sep 14, 2009 | 08:09 PM
JCON's Avatar
JCON
I want to do the same thing on mine, want to do a write up?
Old Sep 14, 2009 | 08:16 PM
Murphdog's Avatar
Murphdog
I have that sitting in the garage waiting to be installed. Not the gentex version, but the actual one from the Ford Accessories website. I don't seem to have the patience to install something like that so I may get someone else to do it, but I would definately like to see if someone has a write up on this...
I purchased it the same time I got the Smart Alert system.
Old Sep 15, 2009 | 12:28 AM
Lethaldosage423
thanks! that is for sure on my christmas list!
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
