Tail light problem
Old Jan 8, 2009 | 11:50 AM
Nuke's Avatar
Nuke
This may be a stupid question but...
Since the brake, hazard and turn signals all work on a seperate filament from the running lights, have you checked to make sure those filaments aren't shot? All it takes is removing the bulbs and a VOM.
Old Jan 8, 2009 | 11:52 AM
Joolander's Avatar
Joolander
Lord High Protector
no i have not done that
also, what is a VOM?
if its a volt meter, i dont have one
Old Jan 8, 2009 | 12:09 PM
Nuke's Avatar
Nuke
Volt Ohm Meter. But anything that'll work as a circuit continuity tester to prove the filament is good would work. And with these types of bulbs, you can hold them up to the sky and SEE both filaments. Rarely have I seen where the filament looked intact and the bulb was bad.
Old Jan 8, 2009 | 12:12 PM
Joolander's Avatar
Joolander
Lord High Protector
oh, so theres 2 filaments in the bulbs eh?
brb!
2007CalSpec's Avatar
2007CalSpec
+1
That's what I would do.
Old Jan 8, 2009 | 12:27 PM
shoeys08dkcandygt's Avatar
shoeys08dkcandygt
american muscle sells these now. same ones i got from them for christmas.
Nuke's Avatar
Nuke
Originally Posted by Joolander
oh, so theres 2 filaments in the bulbs eh?...
Correct. One filament is used for the running lights (dim) and the other for the brake/turn siganl/hazzard (bright). The backup light bulb has only 1 filament.
Old Jan 8, 2009 | 01:06 PM
Joolander's Avatar
Joolander
Lord High Protector
well i fixed it
it wasnt the filaments
turns out the bottom bolt had gotten wedged in between the running light wires in the harness for the outer two
so then the wires got clamped between the light housing and the body
so i cut the wires open, but them back together (with heat shrink around them so theyre not exposed) and then made sure it wouldnt happen again by wrapping that section with electrical tape
Old Jan 8, 2009 | 01:20 PM
Nuke's Avatar
Nuke
Excellent that it wasn't anything requiring any $$ outlay. Sometimes we're our own worse enemy when it comes to "fixing" things. LOL!
JonnyBlazeGT
Nov 3, 2015 01:10 AM
kdryan
Aug 21, 2015 04:01 PM
jjwinel78
Aug 17, 2015 03:34 PM
chain
Aug 17, 2015 08:52 AM
philster0306
Aug 10, 2015 11:33 AM
