Fuel Pump Replacement
Old Jan 10, 2009 | 07:09 PM
zascott's Avatar
zascott
Default Fuel Pump Replacement
Worth doing yourself or take to shop? My 05 GT will not start, not getting enough fuel. I think the fuel pump is out. Is it worth it to try and do it myself or should I just take it to the local performance shop?
Old Jan 10, 2009 | 07:23 PM
Atlanta_Tider's Avatar
Atlanta_Tider
Do it yourself, just remove the back seat bottom and I think there is an access port to get to it.
Old Jan 10, 2009 | 07:25 PM
zascott's Avatar
zascott
I thought you had to drop the tank. If this is not the case it makes a big difference.
Old Jan 10, 2009 | 07:27 PM
Atlanta_Tider
Its not a bad job! No tank dropping here.
Old Jan 10, 2009 | 07:48 PM
zascott's Avatar
zascott
Thanks, sure hope it is the fuel pump. Not getting any codes.
Old Jan 10, 2009 | 08:10 PM
Atlanta_Tider
Can you hear the pump coming on? I would check/replace the relay 1st.
Old Jan 10, 2009 | 08:24 PM
zascott's Avatar
zascott
I have not had any issues lately. I just went to start it today and it would not start. I have not had issues with sputtering. It wanted to start and the fuel tank read it had between 1/4 and 1/2 tank. I pulled the relay and cant see in as it it grey. I may just tow it to the local performance shop (about 4 miles) and see what they have to say.
Old Jan 10, 2009 | 09:15 PM
RICVA05's Avatar
RICVA05
Have you checked the inertia fuel shut off switch?
Old Jan 10, 2009 | 10:09 PM
zascott's Avatar
zascott
Yes I reset the fuel shut off switch. I really am lost now, it sounds totally different than when I tried to start it earlier.
Old Jan 11, 2009 | 12:21 PM
zascott's Avatar
zascott
This morning I tried to start and it is not responding at all. I guess it is time to tow to the shop.
