launch limiter?
Old Jan 11, 2009 | 08:50 PM
urnamethere's Avatar
urnamethere
Default launch limiter?
so after not moving my car for a few days it wouldnt start so i had to jump start it, after jump starting it i gave it a few revs and noticed that it had a limiter at a little over 4k, keep in mind i have an 05 sixer all stock with the exception of duals. now my question is is it safe to launch it at those rpms or is there a way to adjust it? p.s it only limits it to those rpms while the car is stopped when its moving it allows me to take it all the way to redline
Old Jan 11, 2009 | 08:53 PM
urnamethere
i actually just checked and it limits it at 3750 not 4k like i previously said
Old Jan 11, 2009 | 10:40 PM
Silver Vert 06's Avatar
Silver Vert 06
From the factory the car has a 4k RPM neutral rev limiter. There really is no reason to launch at that high of RPMs. Anymore than 2500 and you will just get a lot of tire spin if you're on street tires. I have an auto so I'm not sure how safe it is to launch at 4k on a manual.
Old Jan 11, 2009 | 11:26 PM
ricekiller06's Avatar
ricekiller06
i personally launch at 3800rpm at the dragstrip running MT tires, and an 8.8 rear end with 3.73's
i blew up the 7.5 i think because it was getting abuse from the clutches slipping over time and eventually boom boom
but mine launches fine there sticks it no spin rarley
Old Jan 11, 2009 | 11:50 PM
urnamethere
is there a way to adjust it and set it at lower rpm's? it is a bit high especially with street tires and an open diff
Old Jan 11, 2009 | 11:56 PM
kpaulhus's Avatar
kpaulhus
your fine. if it was too high ford would have lowered it when they made the car
firehorse02
Nov 16, 2015 11:28 AM
ctgreddy
Oct 14, 2015 09:05 PM
TCStangerv6
Oct 11, 2015 05:57 PM
treesloth
Sep 28, 2015 07:03 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
