Stock clutch adjustment???
I was wondering if there is anyway to adjust it to make it easier to push the pedal down in my 05 v6 it is extremely hard to push in compared to my friends v6 and gt that I test drove and it's harder to go into gears than theirs any help
No adjustment as far as I know. You may be due for a clutch replacement, considering yours is an 05. How many miles?
The clutch is a hydraulic unit on my GT, no adjusting.
You may also have a master cylinder or slave cylinder going bad, which could cause increased pedal pressure.
The 'harder to get into gear' kinda makes me think you're needing a new clutch though.
73k right now that's was I was thinking what clutch should I go with I am doing the stw turbo inspring so want some that's not to expensive by a good clutch and is it hard to do yourself I have done it in a dif car before wasn't to hard
