Window Issue
Old Jan 15, 2009 | 04:48 PM
LesteR723's Avatar
LesteR723
Default Window Issue
I have been having issues with my windows for a few months. It started with my passenger window- when i would press the button all the way down and release the window would drop until it was all the way down- as it should. Then when i pulled the button back up- it would stop as soon as i released it. I didnt' feel like this was a big concern until i realized the window also woudln't go up when the door was closed unless i got inside the car from the driver side and put it up with the button. It stopped after a while, started again, then stopped again. Now, my driver window is doing the same thing, which is really frustrating when its raining or i am in a hurry and have to run around to the passenger side, crawl over put the key in and put the window up to seal it up, get out and lock it up then get on my way. Anyone else have this issue or know how it could be fixed?
Old Jan 15, 2009 | 05:23 PM
howarmat's Avatar
howarmat
s197 Junkie
check the manual for the recalibration procedure
Old Jan 15, 2009 | 05:42 PM
07WhiteV6's Avatar
07WhiteV6
Mine, on the drivers side, gets "confused" ocassionally. Eventually, it fixes itself...not sure how, but it does. Maybe it's a certain combination of button presses.
Like howarmat says, check the manual. I'm sure there's something in there about it.
Old Jan 16, 2009 | 11:15 AM
mustangbillyb's Avatar
mustangbillyb
had this issue with my 07; took it to the dealer and they performed a "clocking" procedure;took about 15 minutes and all is well now
Old Jan 16, 2009 | 12:29 PM
d_ames117's Avatar
d_ames117
Do it yourself. I believe all you have to do is open the window all the way. Then close it and hold the button for a few seconds after the window stops moving. The procedure is, however, in the manual.
Dustin
Old Jan 16, 2009 | 12:48 PM
06elnr's Avatar
06elnr
it is in the manual, I think it is push the button down for 10 sec then pull up for 10 sec and then it is calibrated
Old Jan 16, 2009 | 01:36 PM
Mpaint99's Avatar
Mpaint99
Mine did that when the battery was going dead. Changed the battery and never did it again.
Old Jan 16, 2009 | 02:41 PM
avengence's Avatar
avengence
Mine recently didnt do its little roll up to close the gap when you close the door. Mine just mysteriously went away one day and it hasnt done it since.
Old Jan 16, 2009 | 03:09 PM
d_ames117's Avatar
d_ames117
Same issue...do the calibration specified in the manual.
Old Jan 16, 2009 | 06:15 PM
0NF1R's Avatar
0NF1R
i had this problem and it was fixed like so in 2 minutes out in my front yard:
-get in the car and close both doors
-roll the window all the way up, release the switch then hold up on it for 10 sec
-push and hold switch down until the window is all the way down, release the switch then push and hold the switch down for 10 sec
-then just tap the switch up and vioala!
repeat for other door if needed or you can just do both windows at the same time!
