Removing heat shield
Old Jan 18, 2009 | 04:47 PM
VictoriaRR's Avatar
VictoriaRR
Default Removing heat shield
Can anyone tell me how to do this? I'm trying right now with a flathead but the push-pin thingies are not budging. Anyone have some advice?
Old Jan 18, 2009 | 04:48 PM
Joolander's Avatar
Joolander
Lord High Protector
heat shield where?
Old Jan 18, 2009 | 04:50 PM
rford426's Avatar
rford426
on the hood im guessing?
Old Jan 18, 2009 | 05:54 PM
07musclemustang's Avatar
07musclemustang
im thinking exhaust???
Old Jan 18, 2009 | 05:55 PM
07musclemustang
pry bars work wonders for pulling things off... only you may not be able to put them back on
Old Jan 18, 2009 | 05:57 PM
CroDalmatinac's Avatar
CroDalmatinac
Panel Puller...
Old Jan 18, 2009 | 06:25 PM
Mudflap's Avatar
Mudflap
I'm guessing you mean the hood liner push pins? Work it as loose as you can, then stick a pair of needle nose pliers in there and yank it out. You can buy replacements at Autozone, so don't worry too much about damaging them. You should be able to re-use most of not all of them anyway.
Old Jan 18, 2009 | 06:31 PM
05 Mustang's Avatar
05 Mustang
+1^^
I've used pliers in the past to pull them out...you just have to take your time and work one side at a time
Old Jan 18, 2009 | 07:04 PM
odiaz's Avatar
odiaz
easiest way is to use a panel puller. You can pick one up at your local auto parts store for about $5. If you're in the middle of the job and dont want to stop, use a fork. It won't be ideal because it will bend and it will take longer. You'll probably want to throw away the fork when you're done.
Old Jan 18, 2009 | 07:18 PM
Rubrignitz's Avatar
Rubrignitz
now what are you doing, girl? are you trying to remove the heat blanket from your hood? check autozone, they will have a panel puller.
how did the spoiler install go?
