Installing Rousch Rears On Vert - Need Spring Compressor?
Old Jan 23, 2009 | 01:09 PM
mochrome's Avatar
mochrome
Question Installing Rousch Rears On Vert - Need Spring Compressor?
I'm planning to purchase and install a set of Rousch rear springs on my 08 GT convetible to drop the rear about 1 inch and level it out. Do I need a spring comprerssor for this job?
If so, will this one work OK...
http://store.summitracing.com/partde...5&autoview=sku
Any tricks to make this install easy?
Thanks.
Old Jan 23, 2009 | 01:30 PM
07heat's Avatar
07heat
Your local Auto store should have them for free rental usually....
Ford4me1's Avatar
Ford4me1
No. Spring compressor is only needed for the fronts. Disconnect lower control arm with the rearend on an axle jack and car on stands. Then lower jack until the spring comes out. You may have to disconnect the shocks also, mine were removed.
Old Jan 23, 2009 | 02:04 PM
jmk3's Avatar
jmk3
Its a little harder on the vert. You have to remove the frame supports that the coupe does not have. Its not that big of a deal just a lot of bolts. There is a specific torque sequence for reinstallation you better get a manual.
Also don't forget to disconnect the frame mount for the brake hoses or they might get damaged.
I like mine, they level it out nice, it will drop more on a vert than on a coupe.
Old Jan 23, 2009 | 03:29 PM
157dB's Avatar
157dB
Cut & Paste Expert
No compressor needed for the rears.
Disconnect the brake line brackets as well
as the panhard bar.
Old Jan 24, 2009 | 08:34 PM
mochrome's Avatar
mochrome
Thumbs up
Thanks for the install tips. I installed the rear springs today (and a set of GTA axle backs). I didn't need a spring compressor or have to remove the vert frame supports. Looks a lot different. Amazing how just 1" drop in the rear improves the overall look.
Now if UPS will deliver my Bullitt CAI, SCT and Brenspeed tunes I'll be rockin!
drfister
May 3, 2018 10:38 PM
spectreman
Mar 31, 2016 09:26 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Tyoung68
Aug 25, 2015 04:31 AM
MXBT187
Aug 20, 2015 02:36 AM
