Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
- Ford Mustang V6 2005-2014: Why is My Car Losing Power?
Step by step instructions for do-it-yourself repairs.
Car seems to be losing power..no code thrown
What gas are you using? You may need to throw some Lucas treatment in the gas tank and clean the throttle body. Also, make sure everything in the intake is tight. You radio buttons will stay the same.
One other thing it could be and we all suffer from it. You have gotten use to the car and you want more power. It's called MOD disease.
No one has yet to respond about the gas pedal delay.
If you start pushing on the gas pedal and nothing happens for just a little bit, then everything is fine and dandy, you have to deal with the gas pedal mod. Not sure there is a sticky about it, but you can search for "throttle pedal" and find a very detailed how-to in correcting this. link:
https://mustangforums.com/forum/2005...-must-see.html
Nothing that was done at the dealer would cause this.
Today I am going back to the stock COPs to see if any change is noted in performance. If that doesn't fix anything then tomorrow I am doing the gas pedal mod noted above.
If those things don't fix anything I am off to Ernie Haire Ford on the other side of Tampa to see what he can do for me. My local Ford doesn't seem to be much help except for oil changes and minor stuff.
Since I have the AVIC-D3 and not the Shaker1000 I believe the last time I disconnected the battery i lost all my info...
If the throttle pedal seems sluggish, do the "turn the key on, do not start it, depress pedal slowly to the floor, let it back off slowly...turn the key off...then start and drive...." trick.....
It works on mine....
Just be careful!! Also, this issue with the gas pedal would not cause a sudden degradation in power. It is throttle lag that has always been there.....
I will try your little trick now and see what happens.... I'll let ya know. Thanks!!
