Vert lightbar brake light switch location?
I've got the lightbar with the brake light in it and want to disable it. Is there physical depression swich or is it wired into the top's motor circuit?
If I cant get to a switch, where are the wires tapping into the brake light circuit so I can just disconnect them?
They tap in on the passengers side.
Remove the panel and see the wire.
Its tapped into the center mount rear
brake light mounted on the trunk, wire.
The wire is accessed on the passengers
side of the vehicle in the rear seat area
behind the cover that houses the right
rear speaker.
FYI.... It should only work when the top is down
if it was wired correctly when the bar was installed.
rear speaker.
rear speaker.
rear speaker.
musnicki
Sep 23, 2015 07:11 AM
bond007
Aug 26, 2015 11:36 PM
