Camber bolt install
Old Jan 27, 2009 | 04:40 PM
avengence's Avatar
avengence
Default Camber bolt install
Ok so I got some eibach camber bolts from a member here and I was wondering if anyone knows where to find the instructions. I just didnt know if it goes in the top bolt or the bottom bolt spot and which way it faces for adjustment. I also needed to know the torque specs. If anyone knows where the manual is or knows the info that would be great. Thank you!
Old Jan 27, 2009 | 08:30 PM
mjm2007's Avatar
mjm2007
Call Eibach tech support, the # is on their web site!
Old Jan 27, 2009 | 10:38 PM
GrayPony's Avatar
GrayPony
Why not have the shop install them when they do the alignment.
Old Jan 27, 2009 | 11:01 PM
lrgnation's Avatar
lrgnation
ding ding ding
yeah that's the best way unless you happen to have an alignment rack at your house.
Old Jan 28, 2009 | 02:05 AM
tx_zstang's Avatar
tx_zstang
Some shops will charge extra to install the bolts. You can put them in and let them adjust them once they are in. Check with the alignment shop to see if they charge extra for putting the bolts in (would take them a few minutes to remove the stockers and put them in, hence potentially more labor).
Granatelli Sales
Jan 20, 2020 12:34 AM
TimeLord101
Sep 4, 2015 09:27 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
