Interior Upgrade
Old Jan 29, 2009 | 08:58 AM
  #21
bolivianpimp's Avatar
bolivianpimp
How long was the install?
Old Jan 29, 2009 | 09:24 AM
  #22
PennState's Avatar
PennState
Wow that looks great, I would love to do this, how much did it run you for all the LED's and how hard do you think it would be for a beginner..
Old Jan 29, 2009 | 09:30 AM
  #23
vtmustangs's Avatar
vtmustangs
The LEDs were pretty cheap I think I paid $25 maybe but again I didn't have as many to change because I changed out the headunit so that saved me about 20 LEDs. You may need to buy other tools such as a soldering iron and solder. Depends on if you have done soldering before as to how hard it would be. I had never done any soldering before so it took a little while to get used to. I actually somehow ended up burning up the cruise control circuit boards but it was just the iron touched something it shouldn't have. I had never even heard of soldering before I did this; I was such a newb I even said it wrong when went into radioshack to get tools and help from workers.
Old Jan 29, 2009 | 11:00 AM
  #24
PennState's Avatar
PennState
ok thanks, ill give it a try in the spring...i also got an aftermarket radio, so i don't need those either..
Old May 6, 2009 | 10:27 PM
  #25
t0pher90's Avatar
t0pher90
About how long did it take you to do that? it looks ill. def wanna do that.
Old May 6, 2009 | 11:44 PM
  #26
david01130's Avatar
david01130
looks good I like that shifter bezel
Old May 6, 2009 | 11:58 PM
  #27
vtmustangs's Avatar
vtmustangs
It took me awhile but it was my first time soldering anything and I went and checked on each new led instead of just doing them all at once. I would say in all took me probably 5-6 hours but I could easily do it in 3 now that I know how.
Old May 7, 2009 | 02:22 PM
  #28
Shadow7874's Avatar
Shadow7874
What does ford use on the dash? is there 1 led that cycles through all the mycolor options? Id like to find out if its possible to tie it in so that it will change with the colors.
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
b8checker
Sep 30, 2015 07:11 AM
