"Fish Scales" on glass
Old Feb 1, 2009 | 08:54 AM
vaporstang's Avatar
vaporstang
Dumb question - Can they be buffed out with a random orbital polisher with either a polishing compound, glaze, and/or wax? Or is this a bad idea on safety glass?
Old Feb 1, 2009 | 12:42 PM
miloman's Avatar
miloman
Originally Posted by smokestang
I tried all the above, as well as ultra-fine steel wool (which helped some) but still didnt completely get the spots out! in my case it was hard water from a sprinkler system.If you let that water dry in the hot sun it burns it into the glass little by little over time.. by the time i figured it out it was too late!
Wow! Do you live next door to me or something?!?! Exactly my problem. A valve in my sprinkler system stuck open and ran for just over 12 hours. In just so happened to be 106 or 108*F that day..............and it also was one of they only days my car was not parked in the garage
The only way I've found to get it off the paint is polishing, I went to autogeek.com and bought this: http://www.autogeek.net/xmtpocainswr.html
Other than that, wet sanding is your option, but the work is far too extensive.
As far as the windows, I've had no luck with anything. Numerous cleaners, products, steel wool, newspaper.......nothing worked. I want to try the buffer on the window, but I don't need the windows messed up more than they are. Only one person here has mentioned they use a buffer on their windows. That's not enough for me.
Old Feb 1, 2009 | 12:44 PM
miloman's Avatar
miloman
I've been wondering as well.
Old Feb 1, 2009 | 01:00 PM
Rupp's Avatar
Rupp
Thanks for the info guys. I've tried vinegar, pure ammonia, all glass cleaners, clay bar and none of these work. I'll try the steel wool and report back.
Old Feb 1, 2009 | 01:49 PM
munger's Avatar
munger
You need white vinager and water, has always taken hard water spots off for me.
Old Feb 1, 2009 | 02:48 PM
miloman's Avatar
miloman
Don't use anything more than 0000 steel wool. More abrasive wool will probably scratch and swirl.
Old Feb 1, 2009 | 03:53 PM
300GT's Avatar
300GT
yes you should use your random orbital and a polish/pad specific for glass. This is a good one:
http://www.griotsgarage.com/product/...C+16+ounces.do
Old Feb 1, 2009 | 05:48 PM
ptaylor_9849's Avatar
ptaylor_9849
I have lots of experience professionally detailing cars. Yes you can and should use a random orbital to polish glass. Those hard water spots will be gone immediately. Try this and say goodbye to them: http://www.autogeek.net/dia-glasswork-restorer.html
Old Feb 1, 2009 | 10:28 PM
vaporstang's Avatar
vaporstang
Thanks.....that's good to know! I'm even more glad that I purchased my R. O. polisher....
Old Apr 10, 2009 | 12:44 AM
shanec's Avatar
shanec
I just tried some of this for the fish scale problem - http://www.zainostore.com/Merchant2/...oduct_Count=15
1st application took out about 90% of it. I bet the next application will knock out the rest.
