Thumber Comp cams or FRPP Hot Rod cams
i cant decide with ones to go with mostly because of sound. i read the power gains are pretty much the same so it comes down to sound. so if all of you with the two cams or heard them could please chime in and let meknow what you think that would be great
Thanks
Thanks
i already have headers and i am leaning to the hot rod cams cause i do plan on geting an SC down the road and heard i could use the hot rod cams with it is this true ?
Yes you can use them. The gains won't be as high (if any) with the hot rods since they are not designed for FI. But it'll work and with a good dyno tune you won't lose any boost.
If you wanted cams to give you a good/big increase in HP with FI and you still wanted a rough idle then the Comp Cams SPR stage 2 blower cams would be the best choice. They don't lope as much as the Thumpr or Hot Rods but they still have a very rough idle and awesome sound. There's a youtube video from Brenspeed showing these w/ a Saleen blower.
and yeah those blower cams but i want something i can use till then since it will probably be two or three years befor i go FI
Go with the Thumprs. I have them and get compliments on the sound everyday. One lady told me the sound really turned her on.
http://www.youtube.com/watch?v=1S7GfbipgsY
