20x8.5 wheel front need info!!
The higher the offset the closer the face of the rim comes to the brakes. Most common rims that clear GT brakes are 35 mm. My new ones are 25 which bring the wheel lip to closer to the fender and still are under the lip so no rubbing. If its a real deep dish you need to be careful though. But most rims will clear up front. Which brand are u looking at? Thanks for the kind words Zporta.
Thanks Mellow,
very good info, the wheels i purchased are Boss 336's Gray center with polished lip
20x8.5 frt with 33mm offset
20x10 rears with 38 offset
I've spoken to another member who has these wheels and he says in the front he has a little less than 1/4 inch gap from caliper, so if i understand your explanation he must have the 28mm offset wheel.
