help please clear corners
Old Feb 8, 2009 | 09:14 PM
  #21
eddypython's Avatar
eddypython
I had the whole bumper off. I was installing the GT500 bumper and that's when I finally fixed this issue. You can take just the 3 off and get your hands in there to mess around with it, but taking off the whole liner is not that big of PITA. Depends on how easy you want this job to be.
taking the whole thing off makes the job easier but takes longer to put back toghether
taking out the 3 screws only makes it a bit harder but easier to put back toghether. Up to you..
Old Feb 8, 2009 | 09:34 PM
  #22
degeze's Avatar
degeze
Originally Posted by eddypython
the outter part where you have the 2 tabs, I lifted the edge up when I pulled the old ones off and that kept the lenses raised. Mess around with the reinforcment brackets and they'll fit right in...
+2...this is the fix.
I had the same issue.
Old Feb 8, 2009 | 09:35 PM
  #23
Johnboy7701's Avatar
Johnboy7701
Hey eddy I just tinted my tails and my rear marker lights with your write up, next is the front corner marker lights you all are talking about. Ok do I use 2000 grit on those? I went under there to look at them and I guess the easiest way is to unscrew those 3 screws and pull my liner away and whats after that? Thanks for the help you guys...
Old Feb 8, 2009 | 09:47 PM
  #24
eddypython's Avatar
eddypython
yup. Use the same grit you used on your tails. The finer the grit the easier to shine once wetsanded.. 2000 grit is good for those too.
Old Feb 8, 2009 | 10:08 PM
  #25
deekum1627's Avatar
deekum1627
whats weird is i put the factory back in and that fit better
Old Feb 8, 2009 | 10:19 PM
  #26
Johnboy7701
Thanks guys, Ill be pulling off my front markers and spraying those... and finishing up my tails and rear markers I'll post some pics if I get a sunny day when they are done...
Old Feb 9, 2009 | 09:00 AM
  #27
d_ames117's Avatar
d_ames117
The mold they used probably isn't perfect. I'd do what the others have said and fiddle with it. Take the wheel and liner off and it will be a lot less of a struggle.
Dustin
Old Feb 9, 2009 | 09:13 AM
  #28
CutterWolf's Avatar
CutterWolf
I responded to your PM but just to add to it. "no I don't have any gap issues with mine". They pretty much fit just like factory ones but just have a little bit of play to them.
Old Feb 9, 2009 | 09:37 AM
  #29
Joolander's Avatar
Joolander
Lord High Protector
i noticed the same thing as you when i installed them
i also noticed because of the interior color, the gap looks much bigger than it is
just fiddle with those 2 rear tabs a bit, and they'll fit great
Old Feb 9, 2009 | 11:53 AM
  #30
deekum1627's Avatar
deekum1627
ill see what i can do when i get some time thanks for the help everyone
b8checker
Oct 8, 2015 12:55 PM
ChampInSD
Oct 2, 2015 04:55 AM
fastbackford351
Oct 1, 2015 12:24 PM
b8checker
Sep 30, 2015 07:11 AM
